Introdução
If your ORFELD EV-660 has stopped charging entirely or rapidly starts and stops charging, your charging port is most likely the culprit.
O que você precisa
Separate the dust cover and the motor from the vacuum body by pressing the eject button.
Using tweezers, remove the sticker connecting the two halves.
Use the opening pick to gently separate the top half and the bottom half of the vacuum.
Press the blue buttons near the sides of the battery LEDs to remove the top half.
