Ir para o conteúdo principal
ORFELD EV-660-S222 Battery LED Board Replacement
O que você precisa
  1. ORFELD EV-660-S222 Battery LED Board Replacement, Battery LED Board: passo 1, imagem 1 %32
    • Separate the dust cover and the motor from the vacuum body by pressing the eject button.
  2. ORFELD EV-660-S222 Battery LED Board Replacement: passo 2, imagem 1 %32 ORFELD EV-660-S222 Battery LED Board Replacement: passo 2, imagem 2 %32
    • Place the vacuum on its side, with the screws facing towards you.
    • Remove the 11.5 mm screws using a Phillips #1 screwdriver.
  3. ORFELD EV-660-S222 Battery LED Board Replacement: passo 3, imagem 1 %32 ORFELD EV-660-S222 Battery LED Board Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, remove the sticker connecting the two halves.
    • Use the opening pick to gently separate the top half and the bottom half of the vacuum.
    • Press the blue buttons near the sides of the battery LEDs to remove the top half.
  4. ORFELD EV-660-S222 Battery LED Board Replacement: passo 4, imagem 1 %32 ORFELD EV-660-S222 Battery LED Board Replacement: passo 4, imagem 2 %32
    • Slide out the charging port.
  5. ORFELD EV-660-S222 Battery LED Board Replacement: passo 5, imagem 1 %32
    • Lift the battery slightly to reveal the pin connectors.
    • Gently disconnect the six-pin connector that connects to the power button and battery LEDs.
  6. ORFELD EV-660-S222 Battery LED Board Replacement: passo 6, imagem 1 %32 ORFELD EV-660-S222 Battery LED Board Replacement: passo 6, imagem 2 %32 ORFELD EV-660-S222 Battery LED Board Replacement: passo 6, imagem 3 %32
    • Slide out the battery LEDs from the compartment.
    • Remove the plastic LED cover from the LED board.
  7. ORFELD EV-660-S222 Battery LED Board Replacement: passo 7, imagem 1 %32
    • Desolder the LED board from the wires.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 203
