Ir para o conteúdo principal
OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement
O que você precisa
  1. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement, Rear Case: passo 1, imagem 1 %32
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: passo 2, imagem 1 %32 OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: passo 2, imagem 2 %32
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement, Home Button, Volume Buttons and SIM Card Tray: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the home button.
  4. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: passo 4, imagem 1 %32
    • Use tweezers to remove the volume button.
  5. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: passo 5, imagem 1 %32 OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: passo 5, imagem 2 %32
    • In the first photo we rotated the phone 180 degrees. Use tweezers to remove the SIM card tray.
    • The phone has been rotated in the second picture to show where the buttons are removed from.
    • Our home button is not the original home button and is a replacement piece.
Conclusão
4 outras pessoas executaram este guia.
Joshua Stone
Membro desde: 09/26/14
1.067 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 13-5, Staggers Fall 2014 Membro de USF Tampa, Team 13-5, Staggers Fall 2014
USFT-STAGGERS-F14S13G5
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 2,669
