Introdução
Use this guide to replace a broken touchpad.
Ferramentas
Peças
Nenhum componente especificado.
Remove the five 4mm Phillips #1 screws from inside the battery compartment
Remove the eight 4mm Phillips #1 screws attaching the green trim pieces to the lower frame.
Pry off the front and side trim pieces.
Remove the two 4mm Phillips screws that attach the metal plate to the touchpad assembly.
Uma outra pessoa concluiu este guia.
