Ir para o conteúdo principal
OLPC XO-4 Touch Speakers Replacement
O que você precisa
  1. OLPC XO-4 Touch Speakers Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Speakers Replacement: passo 2, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement: passo 2, imagem 2 %32
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Speakers Replacement: passo 3, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement: passo 3, imagem 2 %32
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Speakers Replacement, Screen Frame: passo 4, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement, Screen Frame: passo 4, imagem 2 %32 OLPC XO-4 Touch Speakers Replacement, Screen Frame: passo 4, imagem 3 %32
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Speakers Replacement: passo 5, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement: passo 5, imagem 2 %32 OLPC XO-4 Touch Speakers Replacement: passo 5, imagem 3 %32
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Speakers Replacement: passo 6, imagem 1 %32
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Speakers Replacement: passo 7, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement: passo 7, imagem 2 %32
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
  8. OLPC XO-4 Touch Speakers Replacement, Screen: passo 8, imagem 1 %32
    • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
  9. OLPC XO-4 Touch Speakers Replacement: passo 9, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement: passo 9, imagem 2 %32
    • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
    • Carefully lift the screen out.
  10. OLPC XO-4 Touch Speakers Replacement: passo 10, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement: passo 10, imagem 2 %32 OLPC XO-4 Touch Speakers Replacement: passo 10, imagem 3 %32
    • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
    • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
  11. OLPC XO-4 Touch Speakers Replacement: passo 11, imagem 1 %32
    • Remove the screen from the laptop.
  12. OLPC XO-4 Touch Speakers Replacement, Back Cover: passo 12, imagem 1 %32
    • Remove the four 6mm screws using a Phillips #1 screwdriver.
  13. OLPC XO-4 Touch Speakers Replacement: passo 13, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement: passo 13, imagem 2 %32
    • Rotate the top half of the laptop so that the back cover is facing you.
    • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
    • Remove the back cover by gently lifting it off of the laptop.
  14. OLPC XO-4 Touch Speakers Replacement, Motherboard: passo 14, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement, Motherboard: passo 14, imagem 2 %32 OLPC XO-4 Touch Speakers Replacement, Motherboard: passo 14, imagem 3 %32
    • Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
    • Remove the metal cover from the laptop.
  15. OLPC XO-4 Touch Speakers Replacement: passo 15, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement: passo 15, imagem 2 %32 OLPC XO-4 Touch Speakers Replacement: passo 15, imagem 3 %32
    • Pull the connectors out by holding the plastic tabs and not the wires.
    • Unplug the three wires connecting the motherboard to the bottom half of the laptop.
    • Unplug the two speaker wires from the motherboard.
  16. OLPC XO-4 Touch Speakers Replacement: passo 16, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement: passo 16, imagem 2 %32 OLPC XO-4 Touch Speakers Replacement: passo 16, imagem 3 %32
    • Turn the device over to where the screen used to be.
    • Pull out ribbon cable by holding the purple plastic tab.
    • Pull out connector with the black and white wire by holding plastic tab.
  17. OLPC XO-4 Touch Speakers Replacement: passo 17, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement: passo 17, imagem 2 %32
    • Move the motherboard slightly to the left so that the audio input and output jacks are out of the frame.
    • Pull the motherboard out of the laptop.
  18. OLPC XO-4 Touch Speakers Replacement, Speakers: passo 18, imagem 1 %32 OLPC XO-4 Touch Speakers Replacement, Speakers: passo 18, imagem 2 %32
    • Flip the top half of the laptop around so you are now looking at the front.
    • Pull the two speakers out and carefully pull the wire through and out the hole.
    • There is a small amount of glue holding the speakers in.
Conclusão
Matthew Smith
Membro desde: 01/25/13
23 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 3-29, Amido Winter 2013 Membro de Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 271
