Introdução
Learn how to replace the motherboard on the OLPC XO-4 Touch.
Ferramentas
Peças
Nenhum componente especificado.
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
Gently pull out the two antenna connectors by pulling them away from the motherboard.
Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
Remove the metal cover from the laptop.
Uma outra pessoa concluiu este guia.
