Ir para o conteúdo principal
OLPC XO-4 Touch Keyboard Replacement
O que você precisa
  1. OLPC XO-4 Touch Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Keyboard Replacement: passo 2, imagem 1 %32 OLPC XO-4 Touch Keyboard Replacement: passo 2, imagem 2 %32
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Keyboard Replacement: passo 3, imagem 1 %32 OLPC XO-4 Touch Keyboard Replacement: passo 3, imagem 2 %32
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 OLPC XO-4 Touch Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
  5. OLPC XO-4 Touch Keyboard Replacement: passo 5, imagem 1 %32 OLPC XO-4 Touch Keyboard Replacement: passo 5, imagem 2 %32 OLPC XO-4 Touch Keyboard Replacement: passo 5, imagem 3 %32
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
  6. OLPC XO-4 Touch Keyboard Replacement: passo 6, imagem 1 %32 OLPC XO-4 Touch Keyboard Replacement: passo 6, imagem 2 %32
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
  7. OLPC XO-4 Touch Keyboard Replacement: passo 7, imagem 1 %32 OLPC XO-4 Touch Keyboard Replacement: passo 7, imagem 2 %32
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 3-30, Amido Winter 2013 Membro de Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 41
Ao todo: 1,131
