Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Fix fuzzy, muffled, or a complete absence of sound with a new set of speakers.
O que você precisa
Turn the laptop so it is resting on its bottom.
Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop.
Rotate the top half of the laptop about 90 degrees.
Remove the four 4mm Phillips #1 screws that hold the top cover to the case.
Disconnect the five cables that connect the motherboard to the case by pulling them straight out of their sockets.
