Ir para o conteúdo principal
OLPC XO-1.5 Screen Portion Replacement
O que você precisa
  1. OLPC XO-1.5 Screen Portion Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down with the handle away from you.
  2. OLPC XO-1.5 Screen Portion Replacement: passo 2, imagem 1 %32
    • Slide the tabs out, towards the green edges, to show the open lock symbol.
    • The right tab will stay in place, but the left tab must be held in position while you remove the battery.
  3. OLPC XO-1.5 Screen Portion Replacement: passo 3, imagem 1 %32 OLPC XO-1.5 Screen Portion Replacement: passo 3, imagem 2 %32 OLPC XO-1.5 Screen Portion Replacement: passo 3, imagem 3 %32
    • Lift the middle of the battery to remove it.
  4. OLPC XO-1.5 Screen Portion Replacement, Screen Portion: passo 4, imagem 1 %32
    • Using the Phillips screwdriver, unscrew the 5 size M2 x .4 x 4mm screws underneath the battery.
  5. OLPC XO-1.5 Screen Portion Replacement: passo 5, imagem 1 %32
    • Turn the laptop so that the red XO symbol is right side up.
    • Pull off the white plastic panel with your fingers. There will be 4 tabs that hold the white panel in place. It will require moderate force to remove.
    • If you are having difficulty pulling off the white plastic panel, use a spudger.
  6. OLPC XO-1.5 Screen Portion Replacement: passo 6, imagem 1 %32
    • Unscrew the 4 size M2 x .4 x 4mm screws that are connected to the green plastic.
  7. OLPC XO-1.5 Screen Portion Replacement: passo 7, imagem 1 %32
    • Unplug the white connector with black cables on each end on the left of the hinge.
  8. OLPC XO-1.5 Screen Portion Replacement: passo 8, imagem 1 %32
    • Using the Phillips screwdriver, unscrew the 4 size M3 x .5 x 5mm screws holding the metal to the rest of the laptop.
  9. OLPC XO-1.5 Screen Portion Replacement: passo 9, imagem 1 %32
    • Carefully lift the top half that has the screen away from the bottom half.
    • There is still one black cable connecting the two halves. Be sure not to break it.
  10. OLPC XO-1.5 Screen Portion Replacement: passo 10, imagem 1 %32 OLPC XO-1.5 Screen Portion Replacement: passo 10, imagem 2 %32
    • Rotate the laptop 180 degrees so that the XO logo is now upside down.
    • Remove the center part of green handle. Push the white plastic back cover down away from the keyboard and top half. This should separate easily from the rest of the device.
  11. OLPC XO-1.5 Screen Portion Replacement: passo 11, imagem 1 %32
    • Turn the laptop upside down, exposing the bottom inside of the keyboard.
    • This is similar to how the laptop was positioned when removing the battery, except now the white panel is gone.
  12. OLPC XO-1.5 Screen Portion Replacement: passo 12, imagem 1 %32
    • Slide the black cable (the one that holds the two halves together) out of its connector.
  13. OLPC XO-1.5 Screen Portion Replacement: passo 13, imagem 1 %32 OLPC XO-1.5 Screen Portion Replacement: passo 13, imagem 2 %32
    • Separate the screen portion from the rest of the laptop.
Conclusão
Sam Clark
Membro desde: 10/05/12
61 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 3-19, Amido Fall 2012 Membro de Cal Poly, Team 3-19, Amido Fall 2012
CPSU-AMIDO-F12S3G19
Membros da 6
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 1,076
