Introdução
If your OLPC does not turn on, the physical power button may be damaged. Use this guide to replace a broken or faulty power button.
O que você precisa
Turn the laptop so it is resting on its bottom.
Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop.
Rotate the top half of the laptop about 90 degrees.
Remove the four 4mm Phillips #1 screws that hold the top cover to the case.
Disconnect the five cables that connect the motherboard to the case by pulling them straight out of their sockets.
Push the four power button retaining clips through the bottom of the case with the tip of a screwdriver.
