Ir para o conteúdo principal
Nvidia Shield Tablet Motherboard Replacement
O que você precisa
  1. Nvidia Shield Tablet Motherboard Replacement, Rear Case: passo 1, imagem 1 %32 Nvidia Shield Tablet Motherboard Replacement, Rear Case: passo 1, imagem 2 %32
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Motherboard Replacement: passo 2, imagem 1 %32 Nvidia Shield Tablet Motherboard Replacement: passo 2, imagem 2 %32 Nvidia Shield Tablet Motherboard Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.16
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Motherboard Replacement: passo 3, imagem 1 %32 Nvidia Shield Tablet Motherboard Replacement: passo 3, imagem 2 %32
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Motherboard Replacement, Motherboard: passo 4, imagem 1 %32
    $7.16
    • Carefully use the precision tweezers to unplug the ribbon cable.
    • Be sure to have your anti-static wrist strap on for this procedure.
  5. Nvidia Shield Tablet Motherboard Replacement: passo 5, imagem 1 %32 Nvidia Shield Tablet Motherboard Replacement: passo 5, imagem 2 %32 Nvidia Shield Tablet Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the two 6.5 mm Phillips #00 screws and seven 3.0 mm Phillips #00 screws.
  6. Nvidia Shield Tablet Motherboard Replacement: passo 6, imagem 1 %32 Nvidia Shield Tablet Motherboard Replacement: passo 6, imagem 2 %32 Nvidia Shield Tablet Motherboard Replacement: passo 6, imagem 3 %32
    • Use a pair of tweezers to disconnect the three black antenna cables from the motherboard.
    • Use the flat end of the spudger tool to carefully pry up the motherboard.
    • In the first Shield, the stylus ribbon cable is located under the right side of board. While there are 2 additional cables for the cameras underneath the left end of the board. Be sure to loosen the cameras before lifting the board.
  7. Nvidia Shield Tablet Motherboard Replacement: passo 7, imagem 1 %32 Nvidia Shield Tablet Motherboard Replacement: passo 7, imagem 2 %32
    • Desolder the positive and negative battery cables from the motherboard.
    • Make sure to note which wire goes where, you don't want to re-solder the wires backwards!
    • The motherboard should now come free.
Conclusão
6 outras pessoas executaram este guia.
Molly Bauer
Membro desde: 08/27/15
1.478 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 2-2, Blackwell Fall 2015 Membro de USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Membros
Autoria de 11 guias
9Comentários do guia
Where do you obtain a new motherboard?
imprintcave - Responder
The real question is more about how to find a new shield tablet motherboard ??
willixlive - Responder
where can i buy the motherboard
Gurjot Dhaliwal - Responder
waar kan ik een nieuw shield moederbord kopen?
tom1vangestel - Responder
Hello, I'm looking for a description of the various ribbon connectors on the motherboard.
I'm also looking for a hint to solve a problem I have after replacing the screen+digitizer: the right side (half) of the touch screen does'n work.
Laurent Zanoni - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 35
Ao todo: 9,811
