Ir para o conteúdo principal
Nvidia Shield Tablet K1 Back Panel Replacement
O que você precisa
  1. Nvidia Shield Tablet K1 Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
  2. Nvidia Shield Tablet K1 Back Panel Replacement: passo 2, imagem 1 %32 Nvidia Shield Tablet K1 Back Panel Replacement: passo 2, imagem 2 %32
    • There are clips holding the back panel to the rest of the case. You must apply some force to lift the back panel off.
    • Continue lifting up the panel all the way around the edges of the tablet.
    • Once all of the panel clips are unfastened, gently remove the back panel.
Conclusão
7 outras pessoas executaram este guia.
Ryan Butler
Membro desde: 02/09/16
1.700 Reputação
Autoria de 9 guias
Equipe
iFixit, Team 1-1, Weber Winter 2016 Membro de iFixit, Team 1-1, Weber Winter 2016
FIX-WEBER-W16S1G1
Membros da 4
Autoria de 37 guias
2 comentários
Hello, I’m planning on replacing the battery on my K1 soon, will the rear panel snap back in?
Scott - Responder
but wait theres flex cable your not showing thats attached to the cover it could be ripped off and bricked like mine because no one know the name of said cable
Christian Rogers - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 24
Duração total: 4,982
