Ir para o conteúdo principal
Nvidia Shield TV 1st Generation Motherboard Replacement
O que você precisa
  1. Nvidia Shield TV 1st Generation Motherboard Replacement, Fan/Heat Sink: passo 1, imagem 1 %32
    • Flip the device over and use a plastic opening tool to remove the bottom cover.
  2. Nvidia Shield TV 1st Generation Motherboard Replacement: passo 2, imagem 1 %32 Nvidia Shield TV 1st Generation Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the five screws using T6 Torx screwdriver.
  3. Nvidia Shield TV 1st Generation Motherboard Replacement: passo 3, imagem 1 %32 Nvidia Shield TV 1st Generation Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the power supply cord.
  4. Nvidia Shield TV 1st Generation Motherboard Replacement: passo 4, imagem 1 %32
    • Gently pull the fan away from the edge of the device.
  5. Nvidia Shield TV 1st Generation Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove the five screws using the T6 Torx screwdriver.
    • Thayne Christiansen had a comment on July 20 that I found relevant enough to move up and include in the instructions themselves (still needs verification). "Step 5 shows removal of screws removed in Step 2, but doesn’t show removal of 2 screws from MB freeing it. Should also show removal of two coax cables connected to the board (1 white, 1 black).
  6. Nvidia Shield TV 1st Generation Motherboard Replacement: passo 6, imagem 1 %32
    • Remove cable by carefully pulling it out of the socket.
  7. Nvidia Shield TV 1st Generation Motherboard Replacement: passo 7, imagem 1 %32
    • Tilt and pull the motherboard away from the device.
    • Careful of the thermal paste indicated in the red marker.
Conclusão
5 outras pessoas executaram este guia.
Jessica Tran
Membro desde: 09/25/17
783 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S16-G6, Eyestone Fall 2017 Membro de USF Tampa, Team S16-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S16G6
Membros da 3
Autoria de 7 guias
4 comentários
Where do u get the motherboard
eddie villarejo - Responder
Step 5 shows removal of screws already removed in a different step 2 but doesn’t show the 2 that you have to remove before freeing the MB. Also this doesn’t show removal of the two coax cables connected to the board. one white and one black.
Thayne Christiansen - Responder
I also have the same question as eddie villarejo. Where does one go about finding a replacement motherboard, and furthermore, how much does it cost? I had a specialty electronics store run diagnostics on my NVIDIA SHIELD PRO ANDROID TV (2015) 500GB HD, that just all of the sudden one day stopped displaying video and stopped transmitting audio. The green light still illuminates, and for the first 10 seconds or so after plugging it in, there is a faint sound coming from the device as if it is trying to boot up…but that’s about all. Right now I have a nicely designed paper weight with a cool green illuminating feature…Wow!
The technician who did the diagnostic on it said that he thought (though not sure) that it would cost as much as the device was worth to purchase a new motherboard and install it. That’s the reason for my questions above: 1) Where to get? 2) Cost of replacement?
Thank you for any advice or direction.
Best Regards.
jason.stockdale - Responder
This same scenario happened to me a few days ago. I went ahead and purchased the newer 2018 model, but am in the middle of playing around with repairing this thing. Finding the parts is one thing, but did your technician mention a specific hardware failure that caused your issue or just thinking a motherboard replacement was sufficient?
Drake Simmons -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 68
Duração total: 7,256
