Ir para o conteúdo principal
Nvidia Shield TV 1st Generation I/O Board Replacement
O que você precisa
  1. Nvidia Shield TV 1st Generation I/O Board Replacement, I/O Board: passo 1, imagem 1 %32
    • Flip the device over and use a plastic opening tool to remove the bottom cover.
  2. Nvidia Shield TV 1st Generation I/O Board Replacement: passo 2, imagem 1 %32 Nvidia Shield TV 1st Generation I/O Board Replacement: passo 2, imagem 2 %32
    • Remove the indicated cables and ribbon wires.
  3. Nvidia Shield TV 1st Generation I/O Board Replacement: passo 3, imagem 1 %32 Nvidia Shield TV 1st Generation I/O Board Replacement: passo 3, imagem 2 %32
    • Remove the indicated four screws using the T6 Torx screwdriver.
  4. Nvidia Shield TV 1st Generation I/O Board Replacement: passo 4, imagem 1 %32
    • Carefully tilt and pull out the I/O board from the device.
Conclusão
3 outras pessoas executaram este guia.
Joshua Neally
Membro desde: 09/25/17
581 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S16-G6, Eyestone Fall 2017 Membro de USF Tampa, Team S16-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S16G6
Membros da 3
Autoria de 7 guias
4 comentários
where do i get a new I/O Board ?
Max Eschbach (SAVAGE) - Responder
Yaaa, where can we get the I/O board? :-D
VashCZ - Responder
Yes, i need a replacement I/O board too, where can I find one?
Anand Dhungav - Responder
Where can I get a replacement I/O board? What good are instructions without any availability for parts?
Mike - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 24
Duração total: 3,873
