Ir para o conteúdo principal
Nvidia Shield Pro Android TV Motherboard Replacement
O que você precisa
  1. Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Use a plastic opening tool to pry open the front panel.
  2. Nvidia Shield Pro Android TV Motherboard Replacement: passo 2, imagem 1 %32 Nvidia Shield Pro Android TV Motherboard Replacement: passo 2, imagem 2 %32 Nvidia Shield Pro Android TV Motherboard Replacement: passo 2, imagem 3 %32
    • Use a Torx TR6 screwdriver to remove the five 6mm screws that are securing the fan.
    • Unplug the power supply connected to the fan.
  3. Nvidia Shield Pro Android TV Motherboard Replacement: passo 3, imagem 1 %32 Nvidia Shield Pro Android TV Motherboard Replacement: passo 3, imagem 2 %32
    • Unplug the two black cable bundles that are running over the motherboard.
  4. Nvidia Shield Pro Android TV Motherboard Replacement: passo 4, imagem 1 %32 Nvidia Shield Pro Android TV Motherboard Replacement: passo 4, imagem 2 %32 Nvidia Shield Pro Android TV Motherboard Replacement: passo 4, imagem 3 %32
    • Use a Torx TR6 screwdriver to remove the three 5mm screws securing the motherboard.
    • Detach the black and white coaxial cables from the motherboard.
    • Lift the motherboard out of the device and disconnect the black cable bundle.
Conclusão
Um comentário
Please update the title of this to specify which model year Shield Pro it is for. I was looking for the 2019 model instructions and this obviously isn't that.
Thanks!
jkr4m3r - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 20
Últimos 30 dias: 62
Duração total: 2,559
