Ir para o conteúdo principal
Nvidia Shield Pro Android TV Controller Triggers Replacement
O que você precisa
  1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Bluetooth Controller Thumbsticks: passo 1, imagem 1 %32 Nvidia Shield Pro Android TV Controller Triggers Replacement, Bluetooth Controller Thumbsticks: passo 1, imagem 2 %32 Nvidia Shield Pro Android TV Controller Triggers Replacement, Bluetooth Controller Thumbsticks: passo 1, imagem 3 %32
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 2, imagem 1 %32
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 3, imagem 1 %32 Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 3, imagem 2 %32
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 4, imagem 1 %32 Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 4, imagem 2 %32
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 5, imagem 1 %32 Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 5, imagem 2 %32
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: passo 6, imagem 1 %32 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: passo 6, imagem 2 %32 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: passo 6, imagem 3 %32
    • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
    • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
    • Gently lift the motherboard from the controller housing.
  7. Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 7, imagem 1 %32 Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 7, imagem 2 %32 Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 7, imagem 3 %32
    • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
    • Carefully pull the trigger directly out of its socket.
Conclusão
Um comentário
how do you put the shoulder buttons back in. They fell out when I was trying to replace the battery
demarko9999 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 281
