Ir para o conteúdo principal
Nvidia Shield Pro Android TV Bottom Cover Replacement
O que você precisa
  1. Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: passo 1, imagem 1 %32 Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
Conclusão
Christian De Vera
Membro desde: 01/23/20
167 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S18-G2, White Winter 2020 Membro de Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Membros
Autoria de 14 guias
1Comentário do guia
Hi, Shield Pro 2.
Remove 2 small cross head screws securing top cover to the back plate. Next you have to pry open the back edge and then slide the top cover forwards about 8mm away from the back plate to clear 3 catch points along each side.
S. Carter - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 24
Últimos 30 dias: 66
Ao todo: 2,794
