Ir para o conteúdo principal
NVIDIA SHIELD Portable Motherboard Replacement
O que você precisa
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: passo 1, imagem 1 %32 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: passo 1, imagem 2 %32 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: passo 1, imagem 3 %32
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: passo 2, imagem 1 %32 NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: passo 2, imagem 2 %32
    • The green grill is not screwed in so it can be pulled right out.
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: passo 3, imagem 1 %32 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: passo 3, imagem 2 %32 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: passo 3, imagem 3 %32
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: passo 4, imagem 1 %32
    • Pull the battery apparatus out once all cables are removed.
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: passo 5, imagem 1 %32 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: passo 5, imagem 2 %32 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: passo 5, imagem 3 %32
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: passo 6, imagem 1 %32 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: passo 6, imagem 2 %32 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: passo 6, imagem 3 %32
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
Conclusão
3 outras pessoas executaram este guia.
Marc Perez
Membro desde: 09/29/14
545 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-1, Hickman Fall 2014 Membro de USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
Membros da 4
Autoria de 18 guias
Um comentário
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,801
