Ir para o conteúdo principal
Nvidia Shield Controller Buttons Replacement
O que você precisa
  1. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: passo 1, imagem 1 %32 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: passo 1, imagem 2 %32 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: passo 1, imagem 3 %32
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Controller Buttons Replacement, Remove Green Grill: passo 2, imagem 1 %32 Nvidia Shield Controller Buttons Replacement, Remove Green Grill: passo 2, imagem 2 %32
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: passo 3, imagem 1 %32 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: passo 3, imagem 2 %32 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: passo 3, imagem 3 %32
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Controller Buttons Replacement, Remove Battery Apparatus: passo 4, imagem 1 %32
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Controller Buttons Replacement, Removing Button Board: passo 5, imagem 1 %32 Nvidia Shield Controller Buttons Replacement, Removing Button Board: passo 5, imagem 2 %32 Nvidia Shield Controller Buttons Replacement, Removing Button Board: passo 5, imagem 3 %32
    • Remove seven 6.5 mm T5 torx screws from the button board.
    • Refer to the second image as some screws are not visible in the first image. One of these screws is covered by the orange ribbon.
    • Remove the button board.
Conclusão
7 outras pessoas executaram este guia.
Daniel Eberhart
Membro desde: 09/22/14
379 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-1, Hickman Fall 2014 Membro de USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
Membros da 4
Autoria de 18 guias
2 comentários
From where can I get the buttons?
Chirag Khatri - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 6,098
