Ir para o conteúdo principal
Nvidia Shield Battery Assembly Replacement
O que você precisa
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: passo 1, imagem 1 %32 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: passo 1, imagem 2 %32 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: passo 1, imagem 3 %32
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: passo 2, imagem 1 %32 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: passo 2, imagem 2 %32
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: passo 3, imagem 1 %32 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: passo 3, imagem 2 %32 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: passo 3, imagem 3 %32
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: passo 4, imagem 1 %32
    • Pull the battery apparatus out once all cables are removed.
Conclusão
5 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-1, Hickman Fall 2014 Membro de USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Membros
Autoria de 18 guias
5Comentários do guia
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - Responder Compartilhar
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - Responder Compartilhar
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - Responder Compartilhar
hi! how is this holding up nowadays? i found my old nvidia shield in storage recently and the batteries are completely dead ;;
Canvas - Responder Compartilhar
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 22
Últimos 30 dias: 115
Ao todo: 7,450
