Ir para o conteúdo principal
Nuvision TM800A510L Headphone Jack Replacement
O que você precisa
  1. Nuvision TM800A510L Headphone Jack Replacement, Headphone Jack: passo 1, imagem 1 %32 Nuvision TM800A510L Headphone Jack Replacement, Headphone Jack: passo 1, imagem 2 %32
    • Use a Heat Gun to loosen the adhesive around the inside of the device.
    • Use prying tools to lift the back of the device up.
    • I recommend prying up one side at a time and heating the adhesive to 'just barely too hot to touch'.
  2. Nuvision TM800A510L Headphone Jack Replacement: passo 2, imagem 1 %32
    • Unscrew the headphone jack from the device.
  3. Nuvision TM800A510L Headphone Jack Replacement: passo 3, imagem 1 %32
    • Unlock the headphone jack ribbon.
  4. Nuvision TM800A510L Headphone Jack Replacement: passo 4, imagem 1 %32
    • Move the wires out of the way and slowly pull the ribbon out of the circuit dock.
  5. Nuvision TM800A510L Headphone Jack Replacement: passo 5, imagem 1 %32
    • Lift headphone jack/ribbon out and it's FREE!
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 267
