Ir para o conteúdo principal
Nutribullet Rx #NB-301 Drive Socket Replacement
O que você precisa
  1. Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: passo 1, imagem 1 %32 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: passo 1, imagem 2 %32 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: passo 1, imagem 3 %32
    • Make sure to unplug the device before you start the repair.
    • Flip the blender over so the bottom is facing up.
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the base of the blender.
    • Remove the base cover from the blender.
  2. Nutribullet Rx #NB-301 Drive Socket Replacement: passo 2, imagem 1 %32 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 2, imagem 2 %32
    • Clamp down on the nut above the socket with the needle nose pliers so it stays in place for the next step.
  3. Nutribullet Rx #NB-301 Drive Socket Replacement: passo 3, imagem 1 %32 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 3, imagem 2 %32 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 3, imagem 3 %32
    • Lay the blender on its side and hold the drive socket with the needle nose pliers to keep in from turning so you can remove the screw.
    • Use a Phillips #2 screwdriver to remove the screw securing the drive socket.
  4. Nutribullet Rx #NB-301 Drive Socket Replacement: passo 4, imagem 1 %32 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 4, imagem 2 %32 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 4, imagem 3 %32
    • Remove the drive socket from the motor.
  5. Nutribullet Rx #NB-301 Drive Socket Replacement: passo 5, imagem 1 %32 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 5, imagem 2 %32 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 5, imagem 3 %32
    • Remove all dust and residue from the area before you replace your new drive socket.
  6. Nutribullet Rx #NB-301 Drive Socket Replacement: passo 6, imagem 1 %32 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 6, imagem 2 %32 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 6, imagem 3 %32
    • Use a Phillips #2 screwdriver to secure the drive socket to the motor.
  7. Nutribullet Rx #NB-301 Drive Socket Replacement: passo 7, imagem 1 %32 Nutribullet Rx #NB-301 Drive Socket Replacement: passo 7, imagem 2 %32
    • Place the bottom cover back on the blender.
    • Use the Phillips #2 screwdriver to replace the four 10 mm screws on the back cover back.
Conclusão
Martin G
Membro desde: 03/05/24
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 37
Duração total: 457
