Introdução
The drive socket in your Nutribullet Rx #NB-301 can become loose over time due to frequent usage. When this happens, the drive gear becomes wobbly, causing it to get stuck and stop turning. Fortunately, the drive socket can be replaced. If you are experiencing this issue with your Nutribullet Nutrient Extractor #NB-301, follow this guide to replace the drive socket and start using your blender again!
O que você precisa
Flip the blender over so the bottom is facing up.
Use a Phillips #2 screwdriver to remove the four 10 mm screws from the base of the blender.
Remove the base cover from the blender.
