Ir para o conteúdo principal
Nutri Ninja Ninja Blender Duo BL641 Fan Replacement
O que você precisa
  1. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement, Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: passo 1, imagem 1 %32
    • Turn blender upside down
  2. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: passo 2, imagem 1 %32 Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: passo 2, imagem 2 %32
    • Remove these six screws (0.5 inch 5 gauge phillip's head)
    • Note: 2 of the screws will be star shaped circled in blue
    • Lift the bottom panel off
  3. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: passo 3, imagem 1 %32
    • Unscrew and remove these six phillip's screws. (0.5 inch 5 gauge phillips)
    • Note: The screws circled in blue are 1/8" longer and have a slightly different top than the rest. These are the only two screws that are different than the rest.
  4. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: passo 4, imagem 1 %32 Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: passo 4, imagem 2 %32 Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: passo 4, imagem 3 %32
    • Insert pry tool in between the two plastic pieces to separate them
    • Move pry tool back and forth from right to left until the two pieces begin to separate as shown.
    • Pry the two pieces apart with your hands as shown in the picture to finish separating the pieces.
  5. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: passo 5, imagem 1 %32
    • This completes the disassembly of the main body of the blender so you can continue to perform replacements on the internal parts.
  6. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement, Fan: passo 6, imagem 1 %32
    • Remove this hex nut with the adjustable wrench.
    • Be sure to hold the fan still GENTLY while unscrewing the nut so the bolt does not spin with the nut.
    • Fan may be a little sharp
  7. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: passo 7, imagem 1 %32 Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: passo 7, imagem 2 %32
    • Grab the washer with pliers and twist/pull it off of the threaded rod.
    • The washer is not threaded but has rubbery glue holding it to the threaded rod. This is why unscrewing as well as pulling is necessary.
  8. Nutri Ninja Ninja Blender Duo BL641 Fan Replacement: passo 8, imagem 1 %32
    • Grab the fan gently and pull it off
Conclusão
To reassemble your device, follow these instructions in reverse order along with the body disassembly guide.
Nathan
Membro desde: 09/26/17
201 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S7-G1, Banghart Fall 2017 Membro de Cal Poly, Team S7-G1, Banghart Fall 2017
CPSU-BANGHART-F17S7G1
Membros da 5
Autoria de 6 guias
2 comentários
Buenas noches.
¿Cómo puedo comprar una tarjeta de esta licuadora?
Victor Sosa - Responder
Anyone know where I can get a replacement fan? Google isn't turning up anything for me. :-(
Jackie Grupe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 2,783
