Ir para o conteúdo principal
Introdução
Using this guide, users will be able to replace the cooling vent of their blender.
Peças
Nenhum componente especificado.
  1. Remove the cup from the blender base.
    • Remove the cup from the blender base.
  2. Turn the blender over and unscrew the three 14 mm screws holding the slotted base in place. These are Torx Security bits (TR9) on some units. Turn the blender over and unscrew the three 14 mm screws holding the slotted base in place. These are Torx Security bits (TR9) on some units.
    • Turn the blender over and unscrew the three 14 mm screws holding the slotted base in place. These are Torx Security bits (TR9) on some units.
  3. Using a the standard Phillips head screwdriver bit, remove the slotted black plastic covering and then unscrew the one 11mm screw holding the power cord in place. Unscrew the four 14 mm screws that are in the deep slots.  This will release the motor from the base. Unscrew the four 14 mm screws that are in the deep slots.  This will release the motor from the base.
    • Using a the standard Phillips head screwdriver bit, remove the slotted black plastic covering and then unscrew the one 11mm screw holding the power cord in place.
    • Unscrew the four 14 mm screws that are in the deep slots. This will release the motor from the base.
  4. CAUTION: the silver blade attached to the motor is very sharp.  Use a towel or thick cloth to protect your hands for the next step. Using a towel, hold the silver fan still.  Twist the small black rubber wheel that is attached to the top of the blender base to the right.  This will remove the wheel for replacement. Using a towel, hold the silver fan still.  Twist the small black rubber wheel that is attached to the top of the blender base to the right.  This will remove the wheel for replacement.
    • CAUTION: the silver blade attached to the motor is very sharp. Use a towel or thick cloth to protect your hands for the next step.
    • Using a towel, hold the silver fan still. Twist the small black rubber wheel that is attached to the top of the blender base to the right. This will remove the wheel for replacement.
  5. Slide the cooling vent out from the silver plastic part of the blender base and replace it. Slide the cooling vent out from the silver plastic part of the blender base and replace it.
    • Slide the cooling vent out from the silver plastic part of the blender base and replace it.
Conclusão
Morgan Blauth
Membro desde: 24-02-2016
714 Reputation
5 Guias de autoria
USF Tampa, Team 1-5, Leahy Spring 2016 Membro de USF Tampa, Team 1-5, Leahy Spring 2016
USFT-LEAHY-S16S1G5
2 Membros
5 Guias de autoria
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 506
