Ir para o conteúdo principal
Nuphy Air75 Keyboard Switch Replacement
O que você precisa
  1. Nuphy Air75 Keyboard Switch Replacement, Keyboard Switch: passo 1, imagem 1 %32 Nuphy Air75 Keyboard Switch Replacement, Keyboard Switch: passo 1, imagem 2 %32
    • Place your keyboard on a clean, well-lit surface.
    • Slide the keyboard power switch to the "off" position.
  2. Nuphy Air75 Keyboard Switch Replacement: passo 2, imagem 1 %32 Nuphy Air75 Keyboard Switch Replacement: passo 2, imagem 2 %32 Nuphy Air75 Keyboard Switch Replacement: passo 2, imagem 3 %32
    • Find the wire side of the keycap puller. Slide each wire around opposite sides of the key you are replacing.
    • Pull gently until the key cap comes off.
    • Pull the keycap straight up. This will prevent damage to adjacent keycaps.
  3. Nuphy Air75 Keyboard Switch Replacement: passo 3, imagem 1 %32 Nuphy Air75 Keyboard Switch Replacement: passo 3, imagem 2 %32 Nuphy Air75 Keyboard Switch Replacement: passo 3, imagem 3 %32
    • Use the other side of the switch puller, with two large metal prongs. Fit the prongs onto either side of the switch.
    • Pull the switch out using a side-to-side motion. When one side of the switch lifts up with an audible click, gently lift the other side to fully remove the switch.
    • Do not rock side-to-side into other keys. You can damage adjacent keycaps and the keyboard itself.
  4. Nuphy Air75 Keyboard Switch Replacement: passo 4, imagem 1 %32 Nuphy Air75 Keyboard Switch Replacement: passo 4, imagem 2 %32
    • Orient the replacement switch so that the colored, circular module is facing up.
    • Gently press down until you hear an audible click.
    • Place the keycap over the newly installed switch and gently press down.
  5. Nuphy Air75 Keyboard Switch Replacement: passo 5, imagem 1 %32 Nuphy Air75 Keyboard Switch Replacement: passo 5, imagem 2 %32
    • Turn the power switch to the "wired" or "wireless" position depending on your setup.
    • Test your keyboard and new key switch.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 61
Duração total: 100
