Ir para o conteúdo principal
Numark TT1600 Tone Arm Replacement
O que você precisa
  1. Numark TT1600 Tone Arm Replacement, Tone Arm: passo 1, imagem 1 %32 Numark TT1600 Tone Arm Replacement, Tone Arm: passo 1, imagem 2 %32
    • Flip over the turntable and remove the 9 screws on the outer edges.
  2. Numark TT1600 Tone Arm Replacement: passo 2, imagem 1 %32
    • Remove the back cover by pulling it apart.
  3. Numark TT1600 Tone Arm Replacement: passo 3, imagem 1 %32 Numark TT1600 Tone Arm Replacement: passo 3, imagem 2 %32 Numark TT1600 Tone Arm Replacement: passo 3, imagem 3 %32
    • Remove the clip located on the backside of the audio jack housing by gently pulling it out.
    • There will be some resistance but continue to pull gently.
    • The clip is located right underneath the audio jacks.
  4. Numark TT1600 Tone Arm Replacement: passo 4, imagem 1 %32 Numark TT1600 Tone Arm Replacement: passo 4, imagem 2 %32 Numark TT1600 Tone Arm Replacement: passo 4, imagem 3 %32
    • Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
  5. Numark TT1600 Tone Arm Replacement: passo 5, imagem 1 %32 Numark TT1600 Tone Arm Replacement: passo 5, imagem 2 %32
    • Gently pull the wire that you just unscrewed to release it from the clip.
  6. Numark TT1600 Tone Arm Replacement: passo 6, imagem 1 %32 Numark TT1600 Tone Arm Replacement: passo 6, imagem 2 %32 Numark TT1600 Tone Arm Replacement: passo 6, imagem 3 %32
    • Remove the two screws connecting the circuit board to the tone arm.
  7. Numark TT1600 Tone Arm Replacement: passo 7, imagem 1 %32 Numark TT1600 Tone Arm Replacement: passo 7, imagem 2 %32
    • Remove the two remaining screws connecting the tone arm to the device.
  8. Numark TT1600 Tone Arm Replacement: passo 8, imagem 1 %32
    • Flip the turntable back over to the top side.
    • Remove the counter weight located at the back of the tone arm.
  9. Numark TT1600 Tone Arm Replacement: passo 9, imagem 1 %32 Numark TT1600 Tone Arm Replacement: passo 9, imagem 2 %32 Numark TT1600 Tone Arm Replacement: passo 9, imagem 3 %32
    • Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver.
    • Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
  10. Numark TT1600 Tone Arm Replacement: passo 10, imagem 1 %32 Numark TT1600 Tone Arm Replacement: passo 10, imagem 2 %32 Numark TT1600 Tone Arm Replacement: passo 10, imagem 3 %32
    • Pick up the tone arm and point the back end of it towards its base.
    • Push the back end of the tone arm into the hole.
    • Flip the turntable over and pull the tone arm all the way through the hole.
Conclusão
3 outras pessoas executaram este guia.
Nikolai
Membro desde: 10/12/11
254 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-14, Regan Fall 2011 Membro de Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 27
Duração total: 8,205
