Ir para o conteúdo principal
Numark TT1600 Belt Drive Replacement
  1. Numark TT1600 Belt Drive Replacement, Belt Drive: passo 1, imagem 1 %32
    • Remove slip mat from top of the platter.
  2. Numark TT1600 Belt Drive Replacement: passo 2, imagem 1 %32
    • Remove platter by inserting thumbs in holes and slowly pulling up.
    • There will be some initial resistance.
  3. Numark TT1600 Belt Drive Replacement: passo 3, imagem 1 %32
    • Remove damaged belt which will be located below the platter.
  4. Numark TT1600 Belt Drive Replacement: passo 4, imagem 1 %32
    • Install new belt by securing it around the inner ring, located on the back of the platter.
  5. Numark TT1600 Belt Drive Replacement: passo 5, imagem 1 %32
    • Place a thumb in each hole.
    • You should be able to feel the rubber belt.
    • Gently pull the belt with each thumb, keeping the belt taut around the inner ring.
  6. Numark TT1600 Belt Drive Replacement: passo 6, imagem 1 %32 Numark TT1600 Belt Drive Replacement: passo 6, imagem 2 %32
    • Secure platter back on turntable while keeping belt taut.
    • Pull belt around motor spindle.
    • Gently let go of belt.
  7. Numark TT1600 Belt Drive Replacement: passo 7, imagem 1 %32
    • Test turntable by spinning the platter.
    • There should be slight tension causing the platter to come to a stop.
Linha de Chegada
Nikolai
Membro desde: 10/12/11
254 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-14, Regan Fall 2011 Membro de Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 41
Duração total: 6,250
