Introdução
Most of your time will be getting the back off of the device. The cameras are held down with a little adhesive but are relatively easy to remove.
O que você precisa
Use a Heat Gun to heat the sides of the device one at a time. The Heat Gun will loosen the adhesive.
Use thin tools to pry the back of the device off.
Be advised that you will need to replace the adhesive.
Uma outra pessoa concluiu este guia.
