Ir para o conteúdo principal
NuVision TM1088 Motherboard Replacement
O que você precisa
  1. NuVision TM1088 Motherboard Replacement, Rear Cover: passo 1, imagem 1 %32
    • Place the plastic opening tool between the front and rear cover and pry up on each corner of the cover.
  2. NuVision TM1088 Motherboard Replacement, Motherboard: passo 2, imagem 1 %32
    • Remove the two plugs for the screen by pulling up and away from the motherboard.
  3. NuVision TM1088 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the plug for the cameras by pulling the plug up and away from the motherboard.
  4. NuVision TM1088 Motherboard Replacement: passo 4, imagem 1 %32
    • Melt solder and remove red and black wires leading to the battery.
  5. NuVision TM1088 Motherboard Replacement: passo 5, imagem 1 %32
    • Melt the solder on the black and gray wires and remove wires from motherboard.
  6. NuVision TM1088 Motherboard Replacement: passo 6, imagem 1 %32
    • Melt the solder and remove the red and black wires leading to the speaker.
  7. NuVision TM1088 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the four 4 mm Phillips head screws holding in the motherboard.
  8. NuVision TM1088 Motherboard Replacement: passo 8, imagem 1 %32
    • Lift the motherboard away from the front cover assembly.
Conclusão
Uma outra pessoa concluiu este guia.
Nathaniel Nasman
Membro desde: 03/23/15
750 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-1, Miles Spring 2015 Membro de UMass Dartmouth, Team 1-1, Miles Spring 2015
UMASSD-MILES-S15S1G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 1,663
