Introdução
Make sure to be very careful when handling the battery, lithium batteries are prone to exploding when bent or punctured. If the device is experiencing a short life span or any other issues regarding the battery, follow this guide to replace the battery.
O que você precisa
Turn the device screen side down.
Carefully remove the back piece with the iFixit opening tool.
Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
Pry the battery away from the display screen gently using a nylon spudger or the plastic opening tools.
