Ir para o conteúdo principal
Novatel MiFi 2200 Case Replacement
O que você precisa
  1. Novatel MiFi 2200 Case Replacement, Battery: passo 1, imagem 1 %32
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Case Replacement: passo 2, imagem 1 %32
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Case Replacement, Case: passo 3, imagem 1 %32
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Case Replacement: passo 4, imagem 1 %32
    • Once the seal has been broken all the way around, open the cases using your hands.
Conclusão
Justin Russo
Membro desde: 04/15/12
196 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 7-36, Maness Spring 2012 Membro de Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
Membros da 5
Autoria de 5 guias
Um comentário
If case gets damaged, is there a place to but the case
Snehraj Merchant - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 9
Duração total: 1,538
