Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introdução
Splitting the case of the Mifi 2200 is necessary to be able access the internal parts. This is how to go about that.
Peças
Nenhum componente especificado.
  1. Remove the rear cover by pressing down on the cover and pulling it away from the device.
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Place your finger on the back of the battery located near the edge of the device.
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Using a metal spudger, pry open the device around the seam between the front and back cover.
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Once the seal has been broken all the way around, open the cases using your hands.
    • Once the seal has been broken all the way around, open the cases using your hands.
Conclusão
2 outras pessoas concluíram este guia.
Justin Russo
Membro desde: 15-04-2012
196 Reputation
3 Guias de autoria
Equipe
Cal Poly, Team 7-36, Maness Spring 2012 Membro de Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Membros
5 Guias de autoria
If case gets damaged, is there a place to but the case
Snehraj Merchant - Responder
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,406
