Pular para o conteúdo principal
Introdução
After many charging cycles, your battery can wear out and eventually lose its ability to hold charge. When that happens, you will need to replace the battery to keep using your Mifi.
Ferramentas
Nenhuma ferramenta especificada.
Peças
  1. Remove the rear cover by pressing down on the cover and pulling it away from the device.
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Place your finger on the back of the battery located near the edge of the device.
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  4. Insert the new battery into the battery slot.
    • Insert the new battery into the battery slot.
    • Make sure to place the battery in with the white arrows facing inward.
  5. Re-install the rear cover by placing the inward end in it's slot. Push down on the cover while sliding it into the slot to snap it back into place.
    • Re-install the rear cover by placing the inward end in it's slot.
    • Push down on the cover while sliding it into the slot to snap it back into place.
Conclusão
Charge your new battery and you are ready to use your Mifi again.
Uma outra pessoa concluiu este guia.
Carissah
Membro desde: 15-04-2012
147 reputação
2 Guias de autoria
Equipe
Cal Poly, Team 7-36, Maness Spring 2012 Membro de Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Membros
5 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 721
