Ir para o conteúdo principal
Novatel MiFi 2200 Antenna Replacement
O que você precisa
  1. Novatel MiFi 2200 Antenna Replacement, Battery: passo 1, imagem 1 %32
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Antenna Replacement: passo 2, imagem 1 %32
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Antenna Replacement, Case: passo 3, imagem 1 %32
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Antenna Replacement: passo 4, imagem 1 %32
    • Once the seal has been broken all the way around, open the cases using your hands.
  5. Novatel MiFi 2200 Antenna Replacement, Antenna: passo 5, imagem 1 %32
    • To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
  6. Novatel MiFi 2200 Antenna Replacement: passo 6, imagem 1 %32
    • Carefully pull out the antenna along the edge of the device.
    • There is adhesive applied to the antenna, so it may not easily detach.
  7. Novatel MiFi 2200 Antenna Replacement: passo 7, imagem 1 %32
    • Reconnect your new antenna to the circuit board in the same position described in step 3.
  8. Novatel MiFi 2200 Antenna Replacement: passo 8, imagem 1 %32
    • Re-lay antenna around the edge and over the adhesive.
    • The antenna can be fitted back into several small recesses along the groove that it was originally inside.
  9. Novatel MiFi 2200 Antenna Replacement: passo 9, imagem 1 %32 Novatel MiFi 2200 Antenna Replacement: passo 9, imagem 2 %32 Novatel MiFi 2200 Antenna Replacement: passo 9, imagem 3 %32
    • Apply double-sided stick tape to the inner top and bottom halves of the device along the seam that was previously unsealed.
    • Snap the two halves together along the adhesive line to reconnect it as it previously was.
Conclusão
With a new antenna, your device should be transmitting a signal as expected. Keep in mind that you will need adhesive tape to keep the device firmly together.
Carissah
Membro desde: 04/15/12
147 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-36, Maness Spring 2012 Membro de Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 439
