Ir para o conteúdo principal
Novatel MiFi 2 4G LTE Hotspot SD Card Replacement
  1. Novatel MiFi 2 4G LTE Hotspot  SD Card  Replacement, SD Card: passo 1, imagem 1 %32 Novatel MiFi 2 4G LTE Hotspot  SD Card  Replacement, SD Card: passo 1, imagem 2 %32
    • Unplug the charger from your Novatel Hotspot device.
    • Place the Novatel Hotspot device face down on a flat, clean surface.
    • Locate the rubber SD Card cover on the bottom left hand side of the device. The cover is labeled “Micro SD.”
  2. Novatel MiFi 2 4G LTE Hotspot  SD Card  Replacement: passo 2, imagem 1 %32
    • Open the SD Card cover by placing your finger on the top of the rubber cover and pulling it down.
    • Remove the faulty SD card from its slot by sliding it out with your finger.
    • This guide does not feature an actual SD Card.
Conclusão
GerardFoley
Membro desde: 10/08/18
351 Reputação
Autoria de 4 guias
Equipe
Marist, Team S1-G5, Chaterdon Fall 2018 Membro de Marist, Team S1-G5, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G5
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 116
