Ir para o conteúdo principal
Novatel MiFi 2 4G LTE Hotspot Battery Replacement
  1. Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery Cover: passo 1, imagem 1 %32 Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery Cover: passo 1, imagem 2 %32 Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery Cover: passo 1, imagem 3 %32
    • Unplug the charger from your Novatel Hotspot device.
    • Place the Novatel Hotspot device face down on a flat, clean surface.
    • Place your thumb under the latch of the black plastic battery cover as shown.
    • Remove the battery cover. This will require some force.
  2. Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery: passo 2, imagem 1 %32 Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery: passo 2, imagem 2 %32
    • Gently place your thumb on the right side of the battery as shown.
    • Remove the battery from its socket by lifting it up and out.
Conclusão
GerardFoley
Membro desde: 10/08/18
351 Reputação
Autoria de 4 guias
Equipe
Marist, Team S1-G5, Chaterdon Fall 2018 Membro de Marist, Team S1-G5, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G5
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 602
