Ir para o conteúdo principal
Nostalgia Electrics RHP-310 Replacing Fan Replacement
O que você precisa
  1. Nostalgia Electrics RHP-310 Replacing Fan Replacement, Power Switch: passo 1, imagem 1 %32
    • Unplug the popper.
    • Lift the lid up to remove it.
  2. Nostalgia Electrics RHP-310 Replacing Fan Replacement: passo 2, imagem 1 %32
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
    • Put the removed screws in a safe place, they will be needed later to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Replacing Fan Replacement: passo 3, imagem 1 %32
    • Flip the base over to view the interior of the base panel.
    • Unscrew the two 10 mm Philips #2 screws from the base panel.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Replacing Fan Replacement: passo 4, imagem 1 %32 Nostalgia Electrics RHP-310 Replacing Fan Replacement: passo 4, imagem 2 %32
    • Locate the power switch connected to the side of the housing.
    • Pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Replacing Fan Replacement: passo 5, imagem 1 %32
    • Remove the wires connected to the power switch that should be detached from the housing.
    • Gently pry the wires loose from the power switch with the plastic opening tool.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Replacing Fan Replacement: passo 6, imagem 1 %32
    • Remove the power switch from the housing unit.
    • You can now replace the power switch, if necessary.
  7. Nostalgia Electrics RHP-310 Replacing Fan Replacement, Replacing Housing: passo 7, imagem 1 %32 Nostalgia Electrics RHP-310 Replacing Fan Replacement, Replacing Housing: passo 7, imagem 2 %32
    • Gently remove the heating component from the popper.
    • Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
    • Save the screws from this step. You will need them to connect the new housing to the white top.
  8. Nostalgia Electrics RHP-310 Replacing Fan Replacement: passo 8, imagem 1 %32
    • Remove the white top from the housing.
  9. Nostalgia Electrics RHP-310 Replacing Fan Replacement, Replacing Fan: passo 9, imagem 1 %32
    • Unscrew the three 10 mm Philips #2 screws that hold the heating component together.
    • Keep the screws in a safe place. You will need them to put the heating component back together.
  10. Nostalgia Electrics RHP-310 Replacing Fan Replacement: passo 10, imagem 1 %32
    • Pull the heating component apart.
  11. Nostalgia Electrics RHP-310 Replacing Fan Replacement: passo 11, imagem 1 %32 Nostalgia Electrics RHP-310 Replacing Fan Replacement: passo 11, imagem 2 %32
    • Locate the fan.
    • Pull the fan off the motor.
    • Do not pull too hard or you will break the motor.
  12. Nostalgia Electrics RHP-310 Replacing Fan Replacement: passo 12, imagem 1 %32
    • You can now replace the fan. If there is debris, clean it out.
Conclusão
Uma outra pessoa concluiu este guia.
Dana Clarke
Membro desde: 09/26/12
50 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 16-57, Forte Fall 2012 Membro de Cal Poly, Team 16-57, Forte Fall 2012
CPSU-FORTE-F12S16G57
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 794
