Ir para o conteúdo principal
Nostalgia Electrics PCM805 Stand Replacement
O que você precisa
  1. Nostalgia Electrics PCM805 Stand Replacement, Unscrewing the base: passo 1, imagem 1 %32 Nostalgia Electrics PCM805 Stand Replacement, Unscrewing the base: passo 1, imagem 2 %32
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Stand Replacement: passo 2, imagem 1 %32
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Stand Replacement, Stand: passo 3, imagem 1 %32
    • Locate the four 10mm Phillips #02 screws on the inside of the panel.
  4. Nostalgia Electrics PCM805 Stand Replacement: passo 4, imagem 1 %32 Nostalgia Electrics PCM805 Stand Replacement: passo 4, imagem 2 %32 Nostalgia Electrics PCM805 Stand Replacement: passo 4, imagem 3 %32
    • Remove the screw of the foot you plan to replace.
    • Place your finger on the back of the the foot you are unscrewing for support.
Conclusão
Carlton
Membro desde: 01/13/15
672 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-5, Hickman Winter 2015 Membro de USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 412
