Ir para o conteúdo principal
Nostalgia Electrics PCM805 Power Switch Replacement
O que você precisa
  1. Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: passo 1, imagem 1 %32 Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: passo 1, imagem 2 %32
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Power Switch Replacement: passo 2, imagem 1 %32
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Power Switch Replacement, Power Switch: passo 3, imagem 1 %32
    • Locate the switch/wire assembly inside the device.
  4. Nostalgia Electrics PCM805 Power Switch Replacement: passo 4, imagem 1 %32
    • Pull back the insulation sleeves to expose the connector heads.
  5. Nostalgia Electrics PCM805 Power Switch Replacement: passo 5, imagem 1 %32 Nostalgia Electrics PCM805 Power Switch Replacement: passo 5, imagem 2 %32
    • Note the color of each wire and the order you remove them.
    • Using a pair of pliers, firmly grip the base of the wire.
    • Be sure to grip where the connector meets the wire and not where the connector covers the switch prong.
    • Pull the wire straight out of the switch.
    • Repeat this step for each wire.
  6. Nostalgia Electrics PCM805 Power Switch Replacement: passo 6, imagem 1 %32 Nostalgia Electrics PCM805 Power Switch Replacement: passo 6, imagem 2 %32
    • Using pliers, pinch tabs at the top and bottom of switch.
    • While pinching the tabs, push the switch until the tabs are on the outside of the device.
  7. Nostalgia Electrics PCM805 Power Switch Replacement: passo 7, imagem 1 %32 Nostalgia Electrics PCM805 Power Switch Replacement: passo 7, imagem 2 %32
    • Remove the switch from the device.
Conclusão
Carlton
Membro desde: 01/13/15
672 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-5, Hickman Winter 2015 Membro de USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
Membros da 5
Autoria de 8 guias
Um comentário
The red light turns on but the disk isnt spinning or heating up and when the out let has power
Manuela Velez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,976
