Ir para o conteúdo principal
Nortel Networks i2004 IP Speaker Replacement
O que você precisa
  1. Nortel Networks i2004 IP Speaker Replacement, Back Cover: passo 1, imagem 1 %32 Nortel Networks i2004 IP Speaker Replacement, Back Cover: passo 1, imagem 2 %32 Nortel Networks i2004 IP Speaker Replacement, Back Cover: passo 1, imagem 3 %32
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Speaker Replacement: passo 2, imagem 1 %32
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Speaker Replacement: passo 3, imagem 1 %32 Nortel Networks i2004 IP Speaker Replacement: passo 3, imagem 2 %32
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Speaker Replacement: passo 4, imagem 1 %32
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Speaker Replacement: passo 5, imagem 1 %32 Nortel Networks i2004 IP Speaker Replacement: passo 5, imagem 2 %32
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Speaker Replacement, Speaker: passo 6, imagem 1 %32
    • Lift the speaker straight up.
    • The speaker may need to be slightly wiggled in order to loosen and remove.
  7. Nortel Networks i2004 IP Speaker Replacement: passo 7, imagem 1 %32
    • Cut the red and white wires as close to the speaker as possible.
    • Wire cutters are preferred, but normal scissors are fine too.
  8. Nortel Networks i2004 IP Speaker Replacement: passo 8, imagem 1 %32 Nortel Networks i2004 IP Speaker Replacement: passo 8, imagem 2 %32
    • Solder wires to new speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Elizabeth
Membro desde: 01/21/12
160 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 10-35, Amido Winter 2012 Membro de Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 10
Duração total: 1,132
