Introdução
Use this guide to replace the midframe of your Nook Tablet. This guide is also a prerequisite for accessing or replacing most of the Nook's internal components.
O que você precisa
Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
Lift up the foam pad at the corner of the battery to reveal the battery connector.
Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
Lift up the foam that covers the power connector and volume connector.
Disconnect the power and volume cables from their sockets on the motherboard.
