Ir para o conteúdo principal
Nook Tablet Battery Replacement
O que você precisa
  1. Nook Tablet Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Flip the Nook over.
  2. Nook Tablet Battery Replacement: passo 2, imagem 1 %32 Nook Tablet Battery Replacement: passo 2, imagem 2 %32
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
    Remove stickers covering T5 screws and remove screws
    badbyz - Responder
    Also, remove the mini SD card first or you may break it taking the back off.
    54pontiac - Responder
  3. Nook Tablet Battery Replacement: passo 3, imagem 1 %32 Nook Tablet Battery Replacement: passo 3, imagem 2 %32
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
  4. Nook Tablet Battery Replacement: passo 4, imagem 1 %32 Nook Tablet Battery Replacement: passo 4, imagem 2 %32
    • Slide the spudger around the edges of the Nook to loosen the back panel.
  5. Nook Tablet Battery Replacement: passo 5, imagem 1 %32
    • Pull the back panel off the Nook.
  6. Nook Tablet Battery Replacement, Screen Bezel: passo 6, imagem 1 %32 Nook Tablet Battery Replacement, Screen Bezel: passo 6, imagem 2 %32
    • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
  7. Nook Tablet Battery Replacement: passo 7, imagem 1 %32 Nook Tablet Battery Replacement: passo 7, imagem 2 %32
    • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
  8. Nook Tablet Battery Replacement, Disconnect the Battery: passo 8, imagem 1 %32 Nook Tablet Battery Replacement, Disconnect the Battery: passo 8, imagem 2 %32
    • Lift up the foam pad at the corner of the battery to reveal the battery connector.
    • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
  9. Nook Tablet Battery Replacement, Midframe: passo 9, imagem 1 %32
    • Lift up the foam that covers the power connector and volume connector.
    • Disconnect the power and volume cables from their sockets on the motherboard.
  10. Nook Tablet Battery Replacement: passo 10, imagem 1 %32 Nook Tablet Battery Replacement: passo 10, imagem 2 %32
    • Carefully lift the silver midframe away from the motherboard and display assembly.
    • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
  11. Nook Tablet Battery Replacement, Taking Out the Battery: passo 11, imagem 1 %32 Nook Tablet Battery Replacement, Taking Out the Battery: passo 11, imagem 2 %32 Nook Tablet Battery Replacement, Taking Out the Battery: passo 11, imagem 3 %32
    • Set aside the motherboard and focus on the metal backing containing the battery.
    • Use the screwdriver or plastic prying tool around the edges of the battery to pry it from its slot in the metal backing.
    • The battery may be held with adhesive. Do not panic if it feels like you are prying too hard just apply careful force until it is no longer stuck.
    • Pick up the battery and remove it making sure to free the cords in the upper left hand corner by sliding it out rather than lifting it.
    It is not necessary to remove the battery for screen replacement
    badbyz - Responder
    Great instructions but where do I get a new screen from?
    rightfootscorer -
    I love your site!! THE REPAIR MANUALS ARE FANTASTIC. I THINK I CAN REPLACE MY NOOK BATTERY BY MYSELF!!thx
    edwardstorer - Responder
    I have done all the above but cannot reconnect the connectors
    worths69 - Responder
  12. Nook Tablet Battery Replacement, Notes for Reassembly: passo 12, imagem 1 %32
    • When replacing the motherboard make sure that the speaker assembly component (small rectangular piece) is in place. It is not attached and needs to be properly aligned.
Conclusão
14 outras pessoas executaram este guia.
Holly Lowe
Membro desde: 09/26/12
238 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 1-4, Propen Fall 2012 Membro de Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
Membros da 4
Autoria de 14 guias
2 comentários
How does one disconnect the battery connection in Step 8? The photo shows it miraculously disconnected and the head of a flathead screwdriver is visible, but it doesn't show how to actually remove that connector which has some sort of interlock. Do you just pry the connector away or do you pry it up? The new battery connector has the same interlock, but gives no clue as to how one would make or remove the connector.
jjsims - Responder
what a bullsh*t way to screw the public….ugh. sticking to fricking books!!!! no battery needed!!
iblobar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 87
Duração total: 40,140
