Introdução
This guide will show you how to remove the back cover revealing the battery. This will allow you to access the inside of the nook tablet and will act as prerequisite for most of the other guides
O que você precisa
Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
Remove the tape covering the round holes to reveal two T5 Torx screws.
Remove the two T5 Torx screws securing the back cover.
To reassemble your device, line up the piece that was removed with how it was on before and then just firmly press down till it snaps into place.
5 outras pessoas executaram este guia.
