Ir para o conteúdo principal
Nook HD+ Speaker Replacement
O que você precisa
  1. Nook HD+ Speaker Replacement, Take off the Top Frame: passo 1, imagem 1 %32
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
    • Pry open the front frame.
  2. Nook HD+ Speaker Replacement, Remove the screws: passo 2, imagem 1 %32 Nook HD+ Speaker Replacement, Remove the screws: passo 2, imagem 2 %32
    • Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
  3. Nook HD+ Speaker Replacement, Remove the Battery: passo 3, imagem 1 %32 Nook HD+ Speaker Replacement, Remove the Battery: passo 3, imagem 2 %32
    • Carefully remove the bottom frame from center chassis.
    • Detach the battery ribbon from the motherboard.
    • Flip the center chaise onto the screen side with the hole positioned on the bottom right hand corner.
  4. Nook HD+ Speaker Replacement, Unscrew the speaker: passo 4, imagem 1 %32
    • In the bottom left hand corner remove the 3 screws that at attached to the speaker
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the mother board.
    • Replace old speaker with new speaker then follow instructions in reverse order to reassemble
Conclusão
Alex Pelicas
Membro desde: 10/17/14
283 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Membro de UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
Membros da 5
Autoria de 10 guias
Um comentário
After purchasing a replacement speaker, these steps worked well. Process to a fairly relaxed 20 minutes.
The only thing I’d add is that the speaker is part # AAC121217U22A, and appears to be a bespoke part containing two speakers.
Knowing what part to look for may help others looking for a replacement part.
Jamal Taylor - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 748
