Ir para o conteúdo principal
Nook HD+ Battery Replacement
O que você precisa
  1. Nook HD+ Battery Replacement, Remove the front frame: passo 1, imagem 1 %32 Nook HD+ Battery Replacement, Remove the front frame: passo 1, imagem 2 %32 Nook HD+ Battery Replacement, Remove the front frame: passo 1, imagem 3 %32
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  2. Nook HD+ Battery Replacement, Remove the screws: passo 2, imagem 1 %32 Nook HD+ Battery Replacement, Remove the screws: passo 2, imagem 2 %32
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Battery Replacement, Remove the chassis: passo 3, imagem 1 %32
    • Carefully remove center chassis from bottom frame.
  4. Nook HD+ Battery Replacement, Detach battery: passo 4, imagem 1 %32 Nook HD+ Battery Replacement, Detach battery: passo 4, imagem 2 %32 Nook HD+ Battery Replacement, Detach battery: passo 4, imagem 3 %32
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Battery Replacement, Remove the battery: passo 5, imagem 1 %32 Nook HD+ Battery Replacement, Remove the battery: passo 5, imagem 2 %32
    • Pry battery off of bottom frame using plastic opening tool.
  6. Nook HD+ Battery Replacement, Place new battery: passo 6, imagem 1 %32
    • Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
Conclusão
12 outras pessoas executaram este guia.
Elijah Gonsalves
Membro desde: 10/24/14
1.049 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Membro de UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
Membros da 5
Autoria de 10 guias
5 comentários
Does model affect battery type? The replacement battery was stated so I'm just curious
Jon - Responder
Where i can buy new battery, or any similar [6000 mAh] ?
Sebastian kukosh - Responder
Anyone have a lead on good batteries?
omarhani - Responder
clear directions, liked this guide
wandat100 - Responder
i have a Barnes and noble nook HD+ and how it won't charger at all.
Tina Brown - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 50
Duração total: 9,471
