Ir para o conteúdo principal
Nook Color Display Replacement
O que você precisa
  1. Nook Color Display Replacement, Back Cover: passo 1, imagem 1 %32 Nook Color Display Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
  2. Nook Color Display Replacement: passo 2, imagem 1 %32 Nook Color Display Replacement: passo 2, imagem 2 %32
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
  3. Nook Color Display Replacement, Front Cover: passo 3, imagem 1 %32
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
  4. Nook Color Display Replacement: passo 4, imagem 1 %32 Nook Color Display Replacement: passo 4, imagem 2 %32
    • Pry off the front panel using the plastic opening tool.
  5. Nook Color Display Replacement: passo 5, imagem 1 %32 Nook Color Display Replacement: passo 5, imagem 2 %32
    • Lift up on the connectors to disconnect them using the plastic opening tool.
  6. Nook Color Display Replacement, Motherboard: passo 6, imagem 1 %32 Nook Color Display Replacement, Motherboard: passo 6, imagem 2 %32 Nook Color Display Replacement, Motherboard: passo 6, imagem 3 %32
    • Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
    You might want to tell them that the little yellow ribbon has a little thing you have to lift to remove the ribbon from the mother board. I thought I killed it. The rest of your instructions are perfect. Thanks
    alicemariebass6860 - Responder
  7. Nook Color Display Replacement: passo 7, imagem 1 %32
    • Remove the easy-to-miss T5 Torx 3.8 mm screw located in the tabbed corner of the device.
  8. Nook Color Display Replacement: passo 8, imagem 1 %32 Nook Color Display Replacement: passo 8, imagem 2 %32
    • Lift the motherboard gently from the side with the larger connector ribbon.
    • Slide the white cable gently from underneath its holding place to free the motherboard completely.
    • Remove the motherboard carefully from the device.
  9. Nook Color Display Replacement, Display: passo 9, imagem 1 %32 Nook Color Display Replacement, Display: passo 9, imagem 2 %32 Nook Color Display Replacement, Display: passo 9, imagem 3 %32
    • Use a plastic opening tool to gently pry the display upwards.
    • Lift the display out with your hands until the display has separated from the frame.
Conclusão
6 outras pessoas executaram este guia.
Matthew Perdomo
Membro desde: 01/20/15
497 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 11-5, Blackwell Winter 2015 Membro de USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
Membros da 3
Autoria de 14 guias
Um comentário
this site doesn't sell the Nook Color display. Where did you get yours?
Suzette Garoutte - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 32
Duração total: 3,579
