Ir para o conteúdo principal
Nook Color Buttons Replacement
O que você precisa
  1. Nook Color Buttons Replacement, Back Cover: passo 1, imagem 1 %32 Nook Color Buttons Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Nook Color Buttons Replacement: passo 2, imagem 1 %32 Nook Color Buttons Replacement: passo 2, imagem 2 %32
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
    Pergunte ao FixBot
    Comentar
  3. Nook Color Buttons Replacement, Front Cover: passo 3, imagem 1 %32
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Nook Color Buttons Replacement: passo 4, imagem 1 %32 Nook Color Buttons Replacement: passo 4, imagem 2 %32
    • Pry off the front panel using the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  5. Nook Color Buttons Replacement: passo 5, imagem 1 %32 Nook Color Buttons Replacement: passo 5, imagem 2 %32
    • Lift up on the connectors to disconnect them using the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  6. Nook Color Buttons Replacement, Buttons: passo 6, imagem 1 %32 Nook Color Buttons Replacement, Buttons: passo 6, imagem 2 %32 Nook Color Buttons Replacement, Buttons: passo 6, imagem 3 %32
    • Once you have removed both the back and front panels of the device, you will isolate the panel which contains the buttons. You will remove the volume buttons on the top right first. Use some force upwards and the button will slide free.
    Pergunte ao FixBot
    Comentar
  7. Nook Color Buttons Replacement: passo 7, imagem 1 %32 Nook Color Buttons Replacement: passo 7, imagem 2 %32 Nook Color Buttons Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Next, you will remove the power button from the top left of the middle portion of your device. Using tweezers you will carefully lift the button from where it sits and remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
John Goly
Membro desde: 01/20/15
529 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 11-5, Blackwell Winter 2015 Membro de USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 1,153
