Introdução
This guide describes the removal of the motherboard from the Nook BNRV300 device. This device is also called the “Nook Simple Touch.”
Removing the motherboard allows access to the display and the plastic front cover frame. Removal of the motherboard also enables you to work on electrical components.
Warning: Using metal tools on the motherboard or any electrical components could cause shock to yourself and/or your device. Using plastic tools reduces this risk, but pay attention when working on your device.
O que você precisa
Turn the Nook over to find the power button along the back upper edge.
Wedge the spudger between the top of the power button and the upper edge of the device.
Push the tool down to pry the button up and off.
Peel off the white sticker that is covering the screw head.
Remove the one 2mm-long screw using a size T5 Torx screwdriver.
