Ir para o conteúdo principal
Noma Pedestal Fan Blade Replacement
O que você precisa
  1. Noma Pedestal Fan Blade Replacement, Fan Blade: passo 1, imagem 1 %32 Noma Pedestal Fan Blade Replacement, Fan Blade: passo 1, imagem 2 %32
    • Undo the clips on the outer edge of the fan.
    • Make sure the fan is disconnected from the power source before starting.
  2. Noma Pedestal Fan Blade Replacement: passo 2, imagem 1 %32 Noma Pedestal Fan Blade Replacement: passo 2, imagem 2 %32
    • Gently remove the front piece by pulling it towards the bottom.
    • Don't pull too hard to avoid damaging the clips on the fan.
  3. Noma Pedestal Fan Blade Replacement: passo 3, imagem 1 %32
    • Turn the cap clockwise and remove it.
  4. Noma Pedestal Fan Blade Replacement: passo 4, imagem 1 %32 Noma Pedestal Fan Blade Replacement: passo 4, imagem 2 %32 Noma Pedestal Fan Blade Replacement: passo 4, imagem 3 %32
    • Lightly pull the faulty blade towards you.
    • Be careful while pulling to not injure yourself.
  5. Noma Pedestal Fan Blade Replacement: passo 5, imagem 1 %32 Noma Pedestal Fan Blade Replacement: passo 5, imagem 2 %32
    • Insert the new fan blade onto the screw .
    • Make sure it's pushed all the way back.
  6. Noma Pedestal Fan Blade Replacement: passo 6, imagem 1 %32 Noma Pedestal Fan Blade Replacement: passo 6, imagem 2 %32
    • Place the cap on the screw and tighten it by turning counterclockwise.
  7. Noma Pedestal Fan Blade Replacement: passo 7, imagem 1 %32 Noma Pedestal Fan Blade Replacement: passo 7, imagem 2 %32
    • After placing the front piece back on, fasten the clips again.
    • Make sure you align the piece to fit perfectly on the top.
Conclusão
This is a relatively easy process and as long as you follow our step-by-step guide it should be easy to fix.
Uma outra pessoa concluiu este guia.
Taha Hashmi
Membro desde: 01/15/24
172 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 736
